Morganino
Jun 26, 2017Tutor
Netgear R7000 and OpenVPN for Android App
Hi, since last OpenVPN for Android App update (v.0.6.73) downloadable at the following link: https://play.google.com/store/apps/details?id=de.blinkt.openvpn OpenSSL version was upgraded to 1.1 and...
- Feb 28, 2018
Thanks everyone for feedback so far. Attached is version 1.0.1. I fixed some typos, added a suggestion to clean up your tftp folder when you're done, and made a note about the OpenVPN version that's most compatible with the document.
Some users looking to work through this doc may find that they can avoid Step 1 by visiting this hidden page:
If the debug page loads and there is an "Enable Telnet" option then you got lucky. Note that either the debug page or the option to "Enable Telnet" may not exist on your device or firmware version. Remember to check that this option is disabled after you're finished because having telnet enabled is a security risk.
BusterGonad
Apr 21, 2018Aspirant
Just followed the excellent guide on my R7000. However, when I export the certificates from the VPN settings on the router - they are still the old ones. Which is odd, since they should have been overwritten in the last step (when unzipping newkeys.zip). Last step appeared succesfully and then rebooted, but even after reboot - still retrieving the old certs from the portal.
Diggie3
Apr 21, 2018Luminary
There are two possibilities:
- newkeys.zip has the old keys inside
- you weren't cd'd into the right folder when you unzipped
Well, there are of course many possibilities but those are the most likely!
- BusterGonadApr 22, 2018Aspirant
Hey Diggie3 - thanks for responding.
On closer inspection turns out my router is a D7000 not a R7000 (did try to update the thread last night but the storm knocked out my internet connection).
Definitely had the new certs copied over ok, they just get replaced after the reboot. Guessing the D7000 either needs some extra steps or won't support updating :(
Thanks for the guide anyway - was good fun following :)
- ElfjeTwaalfjeApr 22, 2018Tutor
Hi Diggie3, great effort and considerate of you to share your knowledge. I read your document and started working through the steps time permitting. I like to share 3 observations so far.
1- At PUTTY step 2b you mention port 22 where in the screen you show 23. Port 23 is also in the result of 1h.
2- Given the long time telnet is enabled if I follow your sequence, why not first calculate the new keys, then enable telnet and so on. Then telnet is not open for that long.
3- The PDf is secured. I understand why. However all information needs to be typed over, including URLs to the software used.
4- Keys now generated. Had to change the paths in VARS.bat to point to the proper %home% and bin path.
Question: when updating the firmware, do I need to redo the change of keys?
- ElfjeTwaalfjeApr 26, 2018Tutor
Just finished. Instructions worked great and resultcis good, as expected. I did them in the sequence as nitrd in my earlier post. I also had to temparary change my router password, as identified by Someone67387463.
