Morganino
Jun 26, 2017Tutor
Netgear R7000 and OpenVPN for Android App
Hi, since last OpenVPN for Android App update (v.0.6.73) downloadable at the following link: https://play.google.com/store/apps/details?id=de.blinkt.openvpn OpenSSL version was upgraded to 1.1 and...
- Feb 28, 2018
Thanks everyone for feedback so far. Attached is version 1.0.1. I fixed some typos, added a suggestion to clean up your tftp folder when you're done, and made a note about the OpenVPN version that's most compatible with the document.
Some users looking to work through this doc may find that they can avoid Step 1 by visiting this hidden page:
If the debug page loads and there is an "Enable Telnet" option then you got lucky. Note that either the debug page or the option to "Enable Telnet" may not exist on your device or firmware version. Remember to check that this option is disabled after you're finished because having telnet enabled is a security risk.
stereoptic
May 01, 2018Tutor
Based upon what I am reading here about the certificates not being unique, I think that your solution is much more secure!
Before I purchased this router, I had built my own VPN using these instructions:
Build a Smart Raspberry Pi VPN Server: Auto Configuring, Plug-n-Play, Use from Anywhere (3rd Edition, Rev 2.0)
Diggie3
May 01, 2018Luminary
Regarding certificate uniqueness,
Modern NG routers, like the R7000, should have unique certificates*, with the main downside being that you only get one client certificate to share among all your clients. Fortunately we at least have manual steps to replace that cert if need.
*Caveat: I haven't checked the beta myself yet but I assume they're not doing anything stupid.
Older generation routers where you can't replace the certs: I would recommend not to use OpenVPN server on them.
