Morganino
Jun 26, 2017Tutor
Netgear R7000 and OpenVPN for Android App
Hi, since last OpenVPN for Android App update (v.0.6.73) downloadable at the following link: https://play.google.com/store/apps/details?id=de.blinkt.openvpn OpenSSL version was upgraded to 1.1 and...
- Feb 28, 2018
Thanks everyone for feedback so far. Attached is version 1.0.1. I fixed some typos, added a suggestion to clean up your tftp folder when you're done, and made a note about the OpenVPN version that's most compatible with the document.
Some users looking to work through this doc may find that they can avoid Step 1 by visiting this hidden page:
If the debug page loads and there is an "Enable Telnet" option then you got lucky. Note that either the debug page or the option to "Enable Telnet" may not exist on your device or firmware version. Remember to check that this option is disabled after you're finished because having telnet enabled is a security risk.
stereoptic
May 02, 2018Tutor
I downloaded the new firmware (you need to download the file as the router does not find this new beta firmware) and re-created new keys. OpenVPN is working fine on my android. Also, the upgrade did not seem to change any settings that I am aware of.
Frankyvee
May 02, 2018Guide
Can you tell me what the exact firmware update file name or version # that you used?
Thank You
- stereopticMay 02, 2018Tutor
It's in my post #110 above:
https://kb.netgear.com/000057097/R7000-Firmware-Version-1-0-9-30-Hot-Fix
- FrankyveeMay 02, 2018Guide
Thank You soo much!!! I got it working! I can get to my cameras now from the outside.....sweet.
- stereopticMay 02, 2018TutorCongrats! Since we probably have the same certificates I can see your cameras too! Just kidding!!
