Morganino
Jun 26, 2017Tutor
Netgear R7000 and OpenVPN for Android App
Hi, since last OpenVPN for Android App update (v.0.6.73) downloadable at the following link: https://play.google.com/store/apps/details?id=de.blinkt.openvpn OpenSSL version was upgraded to 1.1 and...
- Feb 28, 2018
Thanks everyone for feedback so far. Attached is version 1.0.1. I fixed some typos, added a suggestion to clean up your tftp folder when you're done, and made a note about the OpenVPN version that's most compatible with the document.
Some users looking to work through this doc may find that they can avoid Step 1 by visiting this hidden page:
If the debug page loads and there is an "Enable Telnet" option then you got lucky. Note that either the debug page or the option to "Enable Telnet" may not exist on your device or firmware version. Remember to check that this option is disabled after you're finished because having telnet enabled is a security risk.
stereoptic
May 02, 2018Tutor
Congrats! Since we probably have the same certificates I can see your cameras too! Just kidding!!
Frankyvee
May 02, 2018Guide
Haha, I know better. OpenSSL generates unique certs everytime it runs a cert request which is what the router wizard does. :-). I just did not feel like running through the whole manual process of doing it myself. I was just waiting for NG to fix it. Thank You for pointing me to the hot fix.
- stereopticMay 02, 2018TutorThanks for that explanation! :thumbsup:
