Morganino
Jun 26, 2017Tutor
Netgear R7000 and OpenVPN for Android App
Hi, since last OpenVPN for Android App update (v.0.6.73) downloadable at the following link: https://play.google.com/store/apps/details?id=de.blinkt.openvpn OpenSSL version was upgraded to 1.1 and...
- Feb 28, 2018
Thanks everyone for feedback so far. Attached is version 1.0.1. I fixed some typos, added a suggestion to clean up your tftp folder when you're done, and made a note about the OpenVPN version that's most compatible with the document.
Some users looking to work through this doc may find that they can avoid Step 1 by visiting this hidden page:
If the debug page loads and there is an "Enable Telnet" option then you got lucky. Note that either the debug page or the option to "Enable Telnet" may not exist on your device or firmware version. Remember to check that this option is disabled after you're finished because having telnet enabled is a security risk.
Diggie3
Feb 28, 2018Luminary
Ravepants
May 03, 2018Guide
Firmware V1.0.2.46
Hi, thanks for the excellent guide, it did exactly what was needed, however I am still unable to use openvpn.
Im not 100% sure but I think the router I have (UK) may have some sort of SE linux variant, as once I have completed the guide and reboot the certs all go back to md5 variants.
I have tested this by following the guide to the letter, then rebooting and clicking the windows button to get the config = old md5 certs, following again, then NOT rebooting, and doing the same = new sha256 certs.
I've given up for now, but just wanted to add this to the conversation as either something I didi wrong (dont think so) or that the filesystem may be tamper protected.
