scarletandgray
Jan 03, 2019Aspirant
Netgear R7000 drop internet connection
I have the latest patch V1.0.9.60 and now I have to reboot my router at least once or twice a night, and the signal drops all over the place. I can check it once it will have over 500mbs then again i...
- Jan 03, 2019
Cannot find right now, but there is a post about do not install the .60 version. Reinstall the version that was working for you.
myersw
Jan 03, 2019Master
- scarletandgrayJan 03, 2019Aspirant
Thank you going back to lower Firmware worked although it took awhile to install, rebooted several times, but finally got it to work. :) so far so good seems to be working.
