scarletandgray
Jan 03, 2019Aspirant
Netgear R7000 drop internet connection
I have the latest patch V1.0.9.60 and now I have to reboot my router at least once or twice a night, and the signal drops all over the place. I can check it once it will have over 500mbs then again i...
- Jan 03, 2019
Cannot find right now, but there is a post about do not install the .60 version. Reinstall the version that was working for you.
Mzrdisi
I had the same problem and downgrading solved the issue. Quality control seems to be severely lacking with Netgear products. I've never had so many issues this past year with other devices with firmware updates. Updates you expect keep your device secure, so you apply them. I guess with Netgear I need to wait several months first before updating. Seems bizarre....
- scarletandgrayJan 04, 2019Aspirant
Yup I normally install the patch when I see it, from now on going to check the community to see if anyone is having issues before installing. This was the first time I really had any issues with the patch. Over all been pretty happy with my Nighthawk 7000 I have had it since 2013 and still works as it should except for the issue I just encountered. I find that if I reboot it about once I month it seems to keep pretty stable.
