Roberteddy
Nov 12, 2017Aspirant
Netgear R7000 Ethernet ports - Transfer speeds
Hello all you expert people. First off, I read through all the suggested previous posts that "may be related to my question". Got some good info but alas, I'm still a bit confused. My R7000 is ...
- Nov 12, 2017Try different cables. All 4 wire pairs inside an Ethernet cable are used for Gigabit Ethernet.
Check the Ethernet driver settings on the HP. Make sure it's not set to deliberately run at 100 Mbps.
TheEther
Nov 12, 2017Guru
Roberteddy
I was thinking the same thing. I'll check that when I can rip him away from Diablo.
Something else weird.. the PC that's getting the gigabit speeds was connected to its jack with cat 5, which according to what I've been reading, can't do gigabit.
Thanks for your help.
