mocolo
May 22, 2017Aspirant
Netgear R7000 External Hard Drive Issue
Hi everyone, I have the Netgear R7000 Nighthawk and I'm trying to connect a Western Digital My Book 4TB 2.5 USB 3.0 External Hard Drive (WDBBGB0040HBK-NESN). I am having great trouble. I essent...
- May 30, 2017
Hi James,
I figured out a solution right after I posted the message to the forum, so I didn't try the method you sent. What ended up working for me was that I reformatted the external hard drive from ExFAT to NTFS. As soon as I did that, I had no problem plugging it into the USB 3.0 port and accessing the drive via ready share.
JamesGL
May 25, 2017NETGEAR Employee Retired
Hi mocolo,
Will the router detects the drive? Can you see it on the UI under ReadyShare? If yes, try this KB.
https://kb.netgear.com/19948/Map-to-a-ReadySHARE-Drive-in-OS-X-with-Auto-Reconnect-after-Reboot
- JamesGLMay 29, 2017NETGEAR Employee Retired
Hi mocolo,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- mocoloMay 30, 2017Aspirant
Hi James,
