krakesh
Feb 21, 2019Aspirant
Netgear R7000 firmware downgrade
Hi, I am planning to flash ddwrt image into Netgear R7000 router, for that the firmware version in the router should be V1.0.3.56 but currently the firmware version is V1.0.9.34_10.2.36 . So can you ...
- Mar 01, 2019
Hello krakesh - Please refer to the following article as the same procedures apply.
https://kb.netgear.com/23960/How-do-I-manually-upgrade-firmware-to-my-NETGEAR-router
~Christian
Christian_R
Feb 27, 2019NETGEAR Employee Retired
Hi krakesh - You can refer to the link below to view previous firmwares for the R7000.
https://www.netgear.com/support/product/r7000.aspx#download
~Christian
- krakeshFeb 28, 2019Aspirant
Hi Christian,
Thanks for responding. Actually I can able to find the firmware files, but I want to downgrade my firmware from 1.0.9.34 version to 1.0.3.56 version. Is it even possible?. If it is possible please do share the steps.
- Christian_RMar 01, 2019NETGEAR Employee Retired
~Christian
