malacath's avatar
malacath
Netgear R7000 IPv6 ICMP Filtered
When going to http://ipv6-test.com/
The test only gives my 17/20
The reason is that ICMP is filtered which according to that site is a bad thing.
I know it is definately the router doing the filtering because I know how to stop windows filtering it and android doesn't filter it by default.
I have looked in the router interface settings and cannot find any setting that will stop ICMPv6 being filtered.
Is this website correct?
Is filtering ICMP really a problem?
Will it cause problems when websites start going ipv6 only?
I have owned the router a few months now and it would be the perfect router if it wasn't for this website saying ICMP filtering is a problem.
    Yes.
    It can be a problem.  IPv6 relies on something calling PMTUD (Path MTU Discovery) to work.  Blocking ICMPv6 prevents PMTUD from working.  Unfortunately, unblocking ICMPv6 has a downside.  It can expose your devices to a certain kind of DoS attack (atomic fragment attack).  This puts you in a "Damned if you do.  Damned if you don't." situation.  There is work ongoing in the IETF (the standards group for TCP/IP Protocols) to figure out how to fix this.
    In the meantime, you may find that things will work even without ICMPv6.  Consider yourself lucky.
    Yes.
    • malacath's avatar
      malacath
      Thanks for the info.
      Sounds like it's nothing to worry about for now?
      • TheEther's avatar
        TheEther
        Guru
        You may be lucky and everything works.  Or you may find that certain destinations are unreachable.
