khojaluna
Dec 29, 2022Follower
Netgear R7000 Lags or drops out
So I've had a R7000 for a year now and its been working "fine" most of the time. However, ive had numerous problems with the wireless internet which is it either dropping out for 5-10 mins, or just HUGE amount of ping. Note that the router is straight under my room so roughly 1m away from my pc.
2.4 Ghz - lags like crazy even when only one device connected. Gets like 25Mbps.
5 Ghz - Either no lag or huge amounts of lag, no in-between. Gets full 250Mbps. 5Ghz wireless drops out for 5-10 mins every 30-60 mins when gaming resulting in me either having no internet or automatically connecting me to the 2.4 with high ping.
Previous Solutions:
Searching for an update through the router website doesn't help, says there is no update available. Going to the router support page often reveals a MUCH newer firmware update available. Need to flash that firmware to the router with an ethernet cable from my laptop. This fixes both the 5Ghz drop-outs and high ping on the 2.4Ghz.
However, this problem reappears every few months which means ill have to update the router manually every month or two to have a stable router.
Why does this happen? Why cant I just have a problem-free router without needing to update its firmware every month??
1 Reply
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
Armor, Circle, Traffic Meter.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
