cvbxcvxfgxfg
Mar 03, 2022Aspirant
Netgear R7000 logs and what they mean?
Good day i was hacked months bck and I was looking around my router and I came across these logs and I keep seeing ddos attack what does these logs mean should I be worried? any help would do I looked up some of the ips I see and some go to bell with address and phone numbers and some go to other ISP any help please thanks God Bless
[DoS attack: Smurf] (11) attack packets in last 20 sec from ip [94.63.161.255], Thursday, Mar 03,2022 10:14:10
[WLAN access rejected: incorrect security] from MAC EC:FA:BC:39:04:5D, Thursday, Mar 03,2022 10:14:09
[LAN access from remote] from 46.10.148.85 to 10.10.10.17:, Thursday, Mar 03,2022 10:14:09
[LAN access from remote] from 88.212.40.139: to 10.10.10.36, Thursday, Mar 03,2022 10:14:09
- microchip8Master
About the DoS attacks, I wouldn't worry much as most are false positives (NG is known for this). About the LAN/WLAN access, you should disable Remote Management as this is always a security risk. A few entries in your log show access to your LAN from remote. I'd worry about that
- cvbxcvxfgxfgAspirant
not sure but i went into the app and turned off anywhere access hope that's what your talking about
- microchip8Master
Don't use cr@ppy apps. They don't offer all the options. Use the Web UI with a browser at http://routerlogin.net or http://192.168.1.1 - once in there, you can turn off Remote Management (I don't recall, but it's somewhere in the Advanced settings)
