duncanc93
Feb 19, 2018Tutor
Netgear R7000 nighthawk settings for xbox 1 x
So im super new to this and i am just trying to figure out the best possible settings for my xbox one x (currently using wifi for now) Im slowing learning what this QoS is for and port forwarding...
- Feb 20, 2018
Well i ended up just factory resetting the router and now im getting around 230-240 mbps on both, latency is around 50-60 which i wish i could get a little lower, i think i might of messed up something in the QoS setup
Feb 19, 2018Guru - Experienced User
True, however NAT issues will be seen in game status like CoD. Secure causes Port Restricted NAT to be used on the router. OPEN causes FULL CONE NAT. FULL CONE NAT is a work around solution for OPEN NAT on multiple game consoles playing same game on the same router. I have two consoles behind my router. One gets OPEN NAT in game an the other gets Moderate or Strict NAT in game untill I change to OPEN NAT FILTER.
