duncanc93
Feb 19, 2018Tutor
Netgear R7000 nighthawk settings for xbox 1 x
So im super new to this and i am just trying to figure out the best possible settings for my xbox one x (currently using wifi for now) Im slowing learning what this QoS is for and port forwarding...
- Feb 20, 2018
Well i ended up just factory resetting the router and now im getting around 230-240 mbps on both, latency is around 50-60 which i wish i could get a little lower, i think i might of messed up something in the QoS setup
Feb 20, 2018Guru - Experienced User
Should be same wired...sure wire is of good quality? CAT6 is recommended.
Make sure you set up QoS priorities for the LAN cable connection.
duncanc93
Feb 20, 2018Tutor
- FURRYe38Feb 20, 2018Guru - Experienced User
Ok, I presumed it may have been a mis configuration. You'll be fine on wired.
- XRaptor29Feb 20, 2018LuminaryI just replaced my R7000 with a XR500 because it kept dogging the wifi down after a few days even on the latest firmware, Wired was perfectly fine though. Rebooting the router would fix it temporarily.
Now my issues are gone with the XR500. - FURRYe38Feb 20, 2018Guru - Experienced User
Enjoy.
