kfilop
Jan 18, 2021Aspirant
Netgear R7000 not getting full internet speed
Hi got My R7000 behind isp router modem its connected throught wan port have being using if fine 2 years till did upgrade from 100mbs line to 200mbs line , devices connects with own seperate ip and...
Jan 18, 2021Guru - Experienced User
What isp gateway is it?
What firmware is on the R7000?
Since the service upgrade, did you ever try a factory reset and reinstall of the r7000?
kfilop
have done a reset fresh installation have latest firmware , isp is in greece have also changed cables
- plemansJan 18, 2021Guru - Experienced User
What "the latest" verison do you have? We ask for a reason and the R7000 isn't known for the best firmware or for even "on the latest" when people say it is.
And what gateway/modem do you have? I didn't need who you're isp is, I needed what gateway model it is
- kfilopJan 18, 2021Aspirant
firmware have
V1.0.9.88_10.2.88Isp cosmote router is Speedport Smart 3 https://www.joom.com/en/products/5dc2c5d78b45130101f4fcaf
diffrent countries take just change abit for needs, but have also another router modem from isp older one speedport plus tried both sam issue . can figure it out.
1. You're not on the latest. The R7000's latest is 1.0.11.110. The agreed upon fastest/stablest is 1.0.9.42. I'd try upgrading over a hardwired connection, doing a factory reset, and then a clean install. If that doesn't help, then I'd try the same process with the older firmware. https://www.netgear.com/support/product/r7000.aspx
2. Your modem isn't just a modem. Its a modem/router combo device. it causes a double nat. https://kb.netgear.com/30186/What-is-Double-NAT
Fixes for that? 1. put the speedport in modem/only passthrough mode. Or you could put the r7000 in access point mode. That would leave only 1 device running routing.
