iAmBlue
May 27, 2020Tutor
Netgear R7000 Rebooting Randomly - Isn't hot to the touch
Hello, I'm having a problem with my R7000 where it will reboot about once per day. Below are my current specs: Model: Netgear R7000 Firmware: V1.0.9.88_10.2.88 OS: Stock OS Environment: Normal ho...
- May 28, 2020
The other thing you see a lot of on here is issues with the firmware for the r7000.
have you tried changing firmware?
I'd recommend version 1.0.9.42. Downgrade to that over a hardwired connection, factory reset the router back to stock, and manually install it.
Then disable auto updates and see how it does.
