iAmBlue
May 27, 2020Tutor
Netgear R7000 Rebooting Randomly - Isn't hot to the touch
Hello, I'm having a problem with my R7000 where it will reboot about once per day. Below are my current specs: Model: Netgear R7000 Firmware: V1.0.9.88_10.2.88 OS: Stock OS Environment: Normal ho...
- May 28, 2020
The other thing you see a lot of on here is issues with the firmware for the r7000.
have you tried changing firmware?
I'd recommend version 1.0.9.42. Downgrade to that over a hardwired connection, factory reset the router back to stock, and manually install it.
Then disable auto updates and see how it does.
iAmBlue
May 30, 2020Tutor
Thanks, it worked. I took a day or two to test it and make sure it didn't reboot or do anything funky, which it didn't. It's just weird how netgear wouldn't fix something major like that with their firmware...
May 30, 2020Guru - Experienced User
Problem with it is that not all devices have the problem. Otherwise it probably would be an easy fix. But for the devices that do have issues, for some reason the 1.0.9.42 firmware tends to work well.
