Retired_Member
Apr 23, 2022NetGear R7000 seems to be in a loop when powering up and all lights keep going on and Off
I have a Netgear R7000 AC1900 unit. When powering it up it seems to try to load and start but seems to not load the software as it keeps going through the motions of all lights coming on, then a few ...
Apr 23, 2022Guru - Experienced User
when you reset, did you push and hold for up to 30 seconds while powered on?
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- wcalifasApr 24, 2022Prodigy
Seems like the firmware has become corrupted. Try unbricking it with the tftp method. Look on youtube "how to debrick a router" follow those steps. You'll have to download the firmware file from the netgear website and also the program tftp2.exe.
