mk0612
Dec 18, 2022Aspirant
NETGEAR R7000 SOAP API
Hello does the NETGEAR R7000 have support for a SOAP API?
michaelkenward
Dec 18, 2022Guru - Experienced User
Did you try this?:
Search - NETGEAR Communities – SOAP API
- mk0612Dec 18, 2022Aspirant
Hello michaelkenward, yes i tried searching for this before posting the question.
When i try to go to /soap/sa_server/ on my router i get a 404 error. So not sure if it is able to be enabled or if its not supported in my model of router.
