imcraigh
Mar 06, 2021Follower
Netgear R7000
Hello all, I have a Netgear R7000 aac1900 , a Netgear GS108E v3, and recently purchased a used Netgear FVS318 Firewall 8 port switch,, and also just got a
AI PoE Switch,52V 65W (4 POE Ports +2 Uplink)100Mbps,802.3af/at,Unmanaged Network Extender POE. I have a Terra-Master 4 bay external NAS dr, an 8 channel Night owl DVR, and one windows10 pc. I've been playing around trying to create sub nets, and trying create vlans
both through the switch and the r7000 router. I've had to reformat my hard drive 7 times in 30 days,and had to reset my router a min of 20 times. PLEASE SOMEONE HELP!
Thanks
1 Reply
Hard to understand what you are asking about. So let's start with that bit.
Why have you had to reformat the hard drive?
Why have you had to reset the router?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
