eghaim
Nov 29, 2021Aspirant
netgear R7000
I have two Netgear R7000. I wanted to see if I could have set one R7000 as base unit ant the other R7000 as a repeater. I did it without conneecting to internet. It worked fine, but discovered seti...
- Nov 29, 2021
All the spelling didn't correct
eghaim wrote:I have two Netgear R7000.
It worked fine, but discovered seting as repeter is no security.
So, I reset the R7000 base unit, all went well, the R7000 repeter unit is now stock.
I am not able to reset becouse the repeater unit keeps trying to reboot every few minutes, the unit never boots up in order to reset.
Even in this condition I tryed pressing the reset button, first 7 seconds, then 30 seconds then 30/30/30 30 reset 30 reset with power off then 30 seconds reset with power on
help
I have two Netgear R7000.I wanted to see if I could have set one R7000 as a base unit and the other R7000 as a repeater. I did it without connecting to the internet.
It worked fine but discovered setting as repeater is no security.
So, I reset the R7000 base unit, all went well, the R7000 repeater unit is now stock.
I am not able to reset because the repeater unit keeps trying to reboot every few minutes, the unit never boots up in order to reset.
Even in this condition, I tried pressing the reset button, first 7 seconds, then 30 seconds then 30/30/30 30 reset 30 reset with power off then 30 seconds reset with power on
help
eghaim
help
help
- FURRYe38Nov 29, 2021Guru - Experienced User
Look at the Advanced Tab/Advanced Settings/Router mode option. Under here you may see Router, AP, Reapter or Bridge modes. If you don't see Repeater here, then the 7000 doesn't support Repeater mode.
- eghaimNov 29, 2021Aspirant
Repeater worked perfectly, but I don't want to use it as a repeater. All I want is to reset to the factory setting.
If you have the IP address of the 7000 series router running in repeater mode, you can log in to the routers web pag using this IP address and configure the Repeater mode back to Router or AP mode. Otherwise, press the reset button in back for 10 seconds and this will put the router back in to router mode.
- michaelkenwardNov 30, 2021Guru - Experienced User
Or read the manual. Always a good move.
Forget about "Repeater " look for Wireless Distribution System.
