eghaim's avatar
eghaim
netgear R7000
I have two Netgear R7000. I wanted to see if I could have set one R7000 as base unit ant the other R7000 as a repeater. I did it without conneecting to internet. It worked fine, but discovered seti...
  • eghaim's avatar
    Nov 29, 2021
    All the spelling didn't correct
    It worked fine, but discovered seting as repeter is no security.
    So, I reset the R7000 base unit, all went well, the R7000 repeter unit is now stock.
    I am not able to reset becouse the repeater unit keeps trying to reboot every few minutes, the unit never boots up in order to reset.
    Even in this condition I tryed pressing the reset button, first 7 seconds, then 30 seconds then 30/30/30 30 reset 30 reset with power off then 30 seconds reset with power on
    help
    I wanted to see if I could have set one R7000 as a base unit and the other R7000 as a repeater. I did it without connecting to the internet.
    It worked fine but discovered setting as repeater is no security.
    So, I reset the R7000 base unit, all went well, the R7000 repeater unit is now stock.
    I am not able to reset because the repeater unit keeps trying to reboot every few minutes, the unit never boots up in order to reset.
    Even in this condition, I tried pressing the reset button, first 7 seconds, then 30 seconds then 30/30/30 30 reset 30 reset with power off then 30 seconds reset with power on
    help
