yabuduwa
Dec 11, 2020Aspirant
Netgear r7000(AC1900) keeps dropping connection when i download
Netgear r7000(AC1900) keeps dropping connection when i download, the whole houses internet disconnects for few minutes and router reboots by itself. i tried to downgrade upgrade my firmware to .34 or...
Dec 11, 2020Guru - Experienced User
What actual firmware version are you on?
what modem/gateway is it connected to?
Are you on wireless or wired when you're having issues?
is it only when 1 device downloads? or when all devices do it?
yabuduwa
V1.0.9.42_10.2.44 It is connected to the wall.
I have issue with both wired or wireless, all devices do it, it will only let the internet download few minutes before disconnecting the whole house.
- plemansDec 12, 2020Guru - Experienced User
- yabuduwaDec 12, 2020AspirantIt is not connect to a modem or gateway, i connect the internet wire from wall to router directly.
- yabuduwaDec 13, 2020AspirantAnd when I download something now, I have to keep the download speed lower than 2000kb/s, by doing this I won’t lose my connection, but any higher download speed would disconnect the whole house and router reboots
- plemansDec 13, 2020Guru - Experienced User
1. that wire is connected to something.
2. when you changed firmwares, did you factory reset and do a clean install? (not from backup) thats key with the r7000
