yabuduwa
Dec 11, 2020Aspirant
Netgear r7000(AC1900) keeps dropping connection when i download
Netgear r7000(AC1900) keeps dropping connection when i download, the whole houses internet disconnects for few minutes and router reboots by itself. i tried to downgrade upgrade my firmware to .34 or...
yabuduwa
V1.0.9.42_10.2.44 It is connected to the wall.
I have issue with both wired or wireless, all devices do it, it will only let the internet download few minutes before disconnecting the whole house.
Dec 12, 2020Guru - Experienced User
what modem/gateway is it connected to?
- yabuduwaDec 12, 2020AspirantIt is not connect to a modem or gateway, i connect the internet wire from wall to router directly.
- yabuduwaDec 13, 2020AspirantAnd when I download something now, I have to keep the download speed lower than 2000kb/s, by doing this I won’t lose my connection, but any higher download speed would disconnect the whole house and router reboots
- plemansDec 13, 2020Guru - Experienced User
1. that wire is connected to something.
2. when you changed firmwares, did you factory reset and do a clean install? (not from backup) thats key with the r7000
- yabuduwaDec 13, 2020Aspirant1. I live in an apartment, I’m not sure if there’s something connected behind the wall, but I connect the wire from wall to r7000 directly.
2. How should I perform that? So I did install the .42 firmware first and then factory reseted it by hold the reset button for 7 seconds, should i factory reset it first and then install? And what do you mean by clean install?
Thank you so much for helping!
