yabuduwa
Dec 11, 2020Aspirant
Netgear r7000(AC1900) keeps dropping connection when i download
Netgear r7000(AC1900) keeps dropping connection when i download, the whole houses internet disconnects for few minutes and router reboots by itself. i tried to downgrade upgrade my firmware to .34 or...
Dec 12, 2020Guru - Experienced User
what modem/gateway is it connected to?
yabuduwa
Dec 13, 2020Aspirant
And when I download something now, I have to keep the download speed lower than 2000kb/s, by doing this I won’t lose my connection, but any higher download speed would disconnect the whole house and router reboots
- plemansDec 13, 2020Guru - Experienced User
1. that wire is connected to something.
2. when you changed firmwares, did you factory reset and do a clean install? (not from backup) thats key with the r7000
- yabuduwaDec 13, 2020Aspirant1. I live in an apartment, I’m not sure if there’s something connected behind the wall, but I connect the wire from wall to r7000 directly.
2. How should I perform that? So I did install the .42 firmware first and then factory reseted it by hold the reset button for 7 seconds, should i factory reset it first and then install? And what do you mean by clean install?
Thank you so much for helping!- plemansDec 13, 2020Guru - Experienced User
I get you plug it in directly. Call whoever your isp is and see whats on the other end of that.
It could be the apartment is running its own router and just supplying all the apartments. Tought to know off limited info.
in terms of clean install it just means to not use a backup configuration whenever changing firmware with the r7000.
