rdsandjs
Jan 27, 2021Initiate
Netgear r7000p & PS5 speed
Recently purchased a PS5 as well as recent upgrade from Xfinity (Comcast) to 600Mbps internet plan. After running a lot of speed tests on phones, laptops, iPads and PS5, the PS5 is maxing out at 188...
Latinoghost
May 28, 2021Initiate
I'm also having the same issue. I have gigablast with Cox, and everthing would get higher speed. The PS5 will never go higher than 100mbps while using CAT6 cable.
