rdsandjs
Jan 27, 2021Initiate
Netgear r7000p & PS5 speed
Recently purchased a PS5 as well as recent upgrade from Xfinity (Comcast) to 600Mbps internet plan. After running a lot of speed tests on phones, laptops, iPads and PS5, the PS5 is maxing out at 188...
Latinoghost
Jun 21, 2021Initiate
I ended up getting rid of the r7000p and got me an ASUS router. I get close to gigabyte on all my wired devices inuding my ps5. If you just got yours, return it.
Mattc0899
Aug 26, 2021Aspirant
Hey so I have the same r7000p and I already swapped it out for a new one but still only get 175mbps download and around 100mbps upload if I’m lucky on wired. Checked different cables same thing, all other devices wired and wireless have better speeds, wifi still not overly fast but ok. Even with PS5 being right next to router I still got under 200. If I bypass the router I got 900mbps upload was only 20 but maybe psn was limiting it, but the speed was 4-5 times more. Can you tell me what Asus router you went with? I want to go get one today, I saw a couple say ps5 compatible but which one did you get to have correct speeds?
