mutedavinci
Aug 07, 2023Follower
Netgear R7000p Dropping Connection (Wired) every 2 hours and 4 minutes.
So I have a Gig up and down fiber optic internet plan. It goes straight from the wall to my router to my pcs with the best ethernet cables I could possibly buy. This router is advertised as being mor...
Aug 07, 2023Guru - Experienced User
Does the top INTERNET LED on the router turn AMBER when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channel configurations are currently set on the router?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
