Retired_Member
Nov 09, 2021Netgear r7000p wifi slow nothing fixes it!
I have a netgear r7000p router 200mbps isp service from spectrum. Since day one at two different houses wifi internet tests I get 21mbps download and 4 mbps upload. So frustrating. App shows speed com...
Nov 09, 2021Guru - Experienced User
1. what modem/gateway is the router connected to?
2. what firmware is on the router?
3. how are you testing the speeds? wired? wireless? IF wireless, are you connecting to 2.4ghz or 5ghz?
4. what wired speeds do you get from the modem?
5. what wired speeds do you get connected to the router?
- Retired_MemberNov 11, 2021Cable modem is a Ubee. Connecting with 5g both hard wired and wireless. I have to look at firmware but I have had this issue since day one with this router. I thought it was isp but it's not
- Retired_MemberNov 11, 2021The speeds are the same roughly 20nton23 mbps download and like 4mbps upload. Also when son is gaming for no reason he starts to lag and it's not the game server bc other friends don't have the issue. This thing is junk
- plemansNov 11, 2021Guru - Experienced User
what ubee modem is it?
- Retired_MemberNov 11, 2021Dvw32c-1 that's the part number
