davidk1952's avatar
davidk1952
Luminary
Nov 26, 2017
Netgear r7500 WLAN access rejected: incorrect security] from MAC address
I have just updated my Nighthawk router and I started to look more closely at the router logs and I have noticed this Warning? [WLAN access rejected: incorrect security] from MAC address ec:3d:fd:42...
  • davidk1952's avatar
    davidk1952
    Nov 27, 2017
    You are correct about driving me crazy... I can't afford to get more gray hair!   But, you are correct there are some options of what you want to log and I"ve started by turning everything off,  then turn on one by one to see what kind of log it creates...   I find objects like Magic Jack will have lots of hits...
    Anyway, I'm going to slowly add what is to be logged and chase it down.. . I"m sure it will be a never ending process..    Thanks for your help...
