Xander7800
Jan 22, 2023Aspirant
Netgear r7800 - not getting gigabit via router but it is possible via the access point
Setup: Modem (ziggo/Cable) --> Router R7800 --> Access Point R7800 About 25 devices (out of 45) are connected (most devices are connected via the AP with 2,4). The Access Point provides wifi for t...
- Jan 23, 2023
Since your Arris device is locked down and providing routing functions, you might consider configuring both R7800s as access points.
Jan 22, 2023Guru - Experienced User
How are you speed testing with the main R7800?
How is the Basic and Advanced Wireless settings configured.
Wired speed tests you shoul see near or just over 900Mpbs on the down.
Wireless, depending on wifi device design and support usually maxes out at around 300-500Mpbs on 5Ghz AC with 80Mhz channel width. If you enable the 160Mhz channel with to support 1733Mpbs on 5Ghz AC and IF your client devices also support 160Mhz, then you could see near 900Mbps and over on 5Ghz AC.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Armor, Circle, Traffic Meter.
The 2nd R7800 in AP would would be correct since it's ethernet connected to the 1st R7800 at 1000Mpbs.
Xander7800
Jan 23, 2023Aspirant
Speedtesting is done via the Nighthawk app (Router and Accesspoint)
I experience the same cap via Wifi AC on the router (between about 600Mb. It can reach 650Mb briefly but then it 'maxes out' - it seems and drops to 500Mb).
Speedtesting via Wifi AC on the AP is about 750-800Mb (Standing close to it). Which is probably pretty good for wifi.
Router uses 160mhz
AP uses 80mhz now (because of DFS issue). The speedtest was done with 160 mhz.
Cablemodem
Arris TG3492LG-ZG
Ziggo is an Internet provider (cable) in the Netherlands (1000 down, 50 up)
Firmware versions
Router and accesspoint: V1.0.2.92
Armor, Circle, Traffic Meter etc. were and are not is use.
- Xander7800Jan 23, 2023Aspirant
Basic wireless (-V = Enabled)
Enable SSID Broadcast - V
Enable 20/40 MHz Coexistence - VWPA2-PSK [AES] - V
2,4 up to 800 (ch -6)
5 up to 1733 (ch - 48)
Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices - V
Enable MU-MIMO - V
Enable HT160 - VWAN
Disable IGMP Proxying - V
Disable SIP ALG - V
Nat filtering open (was secured - no difference in speed)
- FURRYe38Jan 23, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-ModeTry option #2 first...Thought I believe Arris supports option #1.
Option 2 is the current situation.
Option 1 is an option but i cannot do it myself. Ziggo has give the modem its own interface and that option isn't available.
What I do not understand is that the AP can reach up to 950 via the router and modem, but the router cannot and needs the modem to be in bridge mode.
Would be tell if you could swap the R7800 locations with each other and see if the problem continues or moves with the 1st R7800 that is used to connect to the modem.
- michaelkenwardJan 23, 2023Guru - Experienced User
Xander7800 wrote:
Cablemodem
Arris TG3492LG-ZG
The problem start there.
How to set Arris modem to bridged mode - YouTube
