Xander7800
Jan 22, 2023Aspirant
Netgear r7800 - not getting gigabit via router but it is possible via the access point
Setup: Modem (ziggo/Cable) --> Router R7800 --> Access Point R7800 About 25 devices (out of 45) are connected (most devices are connected via the AP with 2,4). The Access Point provides wifi for t...
- Jan 23, 2023
Since your Arris device is locked down and providing routing functions, you might consider configuring both R7800s as access points.
Xander7800
Jan 23, 2023Aspirant
Speedtesting is done via the Nighthawk app (Router and Accesspoint)
I experience the same cap via Wifi AC on the router (between about 600Mb. It can reach 650Mb briefly but then it 'maxes out' - it seems and drops to 500Mb).
Speedtesting via Wifi AC on the AP is about 750-800Mb (Standing close to it). Which is probably pretty good for wifi.
Router uses 160mhz
AP uses 80mhz now (because of DFS issue). The speedtest was done with 160 mhz.
Cablemodem
Arris TG3492LG-ZG
Ziggo is an Internet provider (cable) in the Netherlands (1000 down, 50 up)
Firmware versions
Router and accesspoint: V1.0.2.92
Armor, Circle, Traffic Meter etc. were and are not is use.
Jan 23, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
Try option #2 first...Thought I believe Arris supports option #1.
- Xander7800Jan 23, 2023Aspirant
Option 2 is the current situation.
Option 1 is an option but i cannot do it myself. Ziggo has give the modem its own interface and that option isn't available.
What I do not understand is that the AP can reach up to 950 via the router and modem, but the router cannot and needs the modem to be in bridge mode.
- FURRYe38Jan 23, 2023Guru - Experienced User
Would be tell if you could swap the R7800 locations with each other and see if the problem continues or moves with the 1st R7800 that is used to connect to the modem.
- KitsapJan 23, 2023Master
