Xander7800's avatar
Xander7800
Netgear r7800 - not getting gigabit via router but it is possible via the access point
Setup: Modem (ziggo/Cable) --> Router R7800 --> Access Point R7800 About 25 devices (out of 45) are connected (most devices are connected via the AP with 2,4). The Access Point provides wifi for t...
  • Kitsap's avatar
    Kitsap
    Jan 23, 2023
    Since your Arris device is locked down and providing routing functions, you might consider configuring both R7800s as access points.
