taloOLa
Sep 13, 2021Follower
Netgear R7800 - Turn Remote Management Option Not Showing Up
Hi, I simply can't find Turn Remote Management ON option. Kindly please help :-) Thank you.
Sep 13, 2021Guru - Experienced User
What browser are you using? Try IE11, MS Edge or Firefox?
Has a factory reset been performed since last update and setup from scratch?
- FURRYe38Sep 13, 2021Guru - Experienced User
So ya, This is all thats seen. I just updated my R7800 to v84 and factory reset and setup from scratch. I let the setup wizard enable FW updates and also saw it found a GUI update as well:
Updated and still, all thats seen under Web Services Management:
Is this new behavior for R7800? DarrenM
