chlln
Jan 06, 2019Tutor
Netgear R7800 Dropping connection every few minutes
Starting several days ago my nighthawk r7800 has been dropping all connections on both the 2.4ghz and 5ghz bands varying in intermittence from 1-15 minutes, and occuring on all devices, even after a ...
- Jan 06, 2019
It's the firmware. Netgears last 2 releases .58 and.60 have connection issues and latency problems. This has been talked about on verious forums. The solution right now is to roll back to version .52 or use Voxel's firmware .62. untill NG releaes a fix.
James721
Jan 06, 2019Luminary
chlln
Jan 06, 2019Tutor
Thank you! how/where can i get the old firmware file?
- James721Jan 06, 2019Luminary
Can be downloaded here > https://kb.netgear.com/000058809/R7800-Firmware-Version-1-0-2-52
- chllnJan 06, 2019Tutor
with .52 all problems seem to be resolved, haven't seen a ping over 40ms in 20 mins now...
Thanks for the help, I had factory reset the router and updated the firmware to newest version awhile ago so this makes sense... spent 6-10 hours trying diferent things and learning about troubleshooting networks so thanks for that netgear...
