chlln
Jan 06, 2019Tutor
Netgear R7800 Dropping connection every few minutes
Starting several days ago my nighthawk r7800 has been dropping all connections on both the 2.4ghz and 5ghz bands varying in intermittence from 1-15 minutes, and occuring on all devices, even after a ...
- Jan 06, 2019
It's the firmware. Netgears last 2 releases .58 and.60 have connection issues and latency problems. This has been talked about on verious forums. The solution right now is to roll back to version .52 or use Voxel's firmware .62. untill NG releaes a fix.
chlln
Jan 09, 2019Tutor
What firmware version do you have?(viewable on router control panel)
baddogone1
Jan 09, 2019Tutor
V1.0.4.12
