RJU118's avatar
RJU118
Netgear R7800 ethernet port speed max 100Mbps
Is about a Nighthawk(R) X4S R7800  firmware version V1.0.2.40 Although a gigabith ethernet connection from the modem is connected to the wan port and a gigabit switchport is connected to ethernet LA...
  • TheEther's avatar
    Dec 28, 2017
    One possibility are bad cables. Gigabit Ethernet uses all 4 wire pairs (8 wires) inside the cable. If one or more wires are faulty, then speeds can drop down to 100 Mbps, which only requires 2 wire pairs (4 wires).
    Another possibility is that Ethernet autonegotiation is failing. This is uncommon but it still seems to happen. AFAIK, the Nighthawk doesn't have any settings to control autonegotiation, nor do most modems. One trick that can work is to put a switch in between. The switch may do a better job of autonegotiation than the two devices it is interconnecting. Obviously, this doesn't explain why your existing switch can't negotiate a 1 Gbps speed with your Nighthawk.
    I would first try new cables since that's relatively inexpensive. Good luck.
