DaveSanders
Jun 13, 2018Initiate
Netgear R7800 ethernet throughput issues
Netgear Nighthawk R78900 V1.0.2.52 firmware Windows 10
The R7800 is installed after an Arris Surfboard SB6183 cable modem.
Eperienced thoughtput issues about 2 months ago when the download speed ...
- Jun 14, 2018
Sounds right to me. QoS will slow a connection down which is what you experienced until disabling QoS. QoS will not allow full speed of the Internet connection.
microchip8
Jun 14, 2018Master
yes, and? you found the problem so what else do you want?
- myerswJun 14, 2018Master
- DaveSandersJun 14, 2018Initiate
Hi Bill, what is strange is that I have had QoS enabled for a condiserable time prior to my experiences with the poor throughput performance and was getting around ~180Mbps download.
Dave
