paillassou
Nov 05, 2020Apprentice
Netgear R7800 Firmware 1.0.2.76
2020/04/11 EXACLTLY SAME PROBLEMS WITH TE NEW FIRMWARE v1.0.2.76 Wifi drops in AP MODE / unable to use AP MODE R7800 v1.0.2.76 firmware always contains BUGS Reset the router. Still the same probl...
Codocy
Nov 11, 2020Initiate
Hello from France,
I have exactly the same problems.
Router restarts randomly, since 1.0.2.74.
I have downgraded to 1.0.2.68, no problems.
- Richard76Nov 11, 2020TutorI have tried to downgrade to .68, but that did not work. It was unstable, so i had to go back to .74 still wifi dropping but less then .76
- JayboHNov 12, 2020Apprentice
I've noticed several problems to .76 reported in the forum.
I noticed once I went to it, all connections, local and internet of course would drop, which has never happened in my history with this product. I rolled back to .74, and it still kept happening. I've seen it happen only once with .68, and what is weird is that .74 never used to do it either. I wonder if I should factory reset and then fresh update to .76 because something clearly has gone astray judging by all the issues listed in this and other threads.
- JayboHNov 17, 2020Apprentice
Tried it a 2nd time after a factory reset. No dice. .76 so far in all the years I have had this router is by far the worst firmware update I've seen. ...in fact I don't recall having much problems before this.
