paillassou
Nov 05, 2020Apprentice
Netgear R7800 Firmware 1.0.2.76
2020/04/11 EXACLTLY SAME PROBLEMS WITH TE NEW FIRMWARE v1.0.2.76 Wifi drops in AP MODE / unable to use AP MODE R7800 v1.0.2.76 firmware always contains BUGS Reset the router. Still the same probl...
JayboH
Nov 17, 2020Apprentice
Tried it a 2nd time after a factory reset. No dice. .76 so far in all the years I have had this router is by far the worst firmware update I've seen. ...in fact I don't recall having much problems before this.
Richard76
Nov 17, 2020Tutor
I also never had any problems. Decided to buy a new router... it is almost if they do this un purpose, but i am not buying a netgear router. I switch to Acer RT-AX88U as i do not trust netgear to solve this problem soon. Could have been the netgear AX8, but no thanks as for this sort of problems appears to be with a lot of netgear routers.
- JayboHNov 17, 2020Apprentice
Let us know how if you like it
- JayboHNov 25, 2020Apprentice
Ok so awhile back what I did was factory reset by holding a toothpick in the reset button for half a minute just to be extra sure. When it asks you to update to the latest firmware (.76) I said yes.
Now here's the kicker: do NOT restore your saved settings. Put them in manually one by one.
I haven't had any issues at all now. You can see my past posts that .76 was giving me lots of problems until I did this (I discussed it in several threads, not just this one.)
- Richard76Dec 05, 2020TutorI really like the asus, stable and lots more options. Better range and fast. Highly recomanded.
