paillassou
Dec 06, 2020Apprentice
Netgear R7800 Firmware 1.0.2.78
Netgear R7800 Firmware 1.0.2.78 EXACLTLY SAME PROBLEMS WITH v1.0.2.74 / v1.0.2.76 / v1.0.2.78 Router reboots randomly Wifi drops in AP MODE / unable to use AP MODE R7800 v1.0.2.78 firmware al...
SomeGuySpeaking
Dec 11, 2020Initiate
Router mode. Was able to get it working on .74 firmware. Tried .78 and same issues again.
JayboH
Dec 11, 2020Apprentice
After what happened to me earlier, I always now do a clean install every time and manually put in my settings instead of loading from a save. So far so good.
- TacticalTimboDec 11, 2020Initiate
What is this 'clean install' you speak of?
- JayboHDec 12, 2020Apprentice
Basically hold the Reset button in with a toothpick for over half a minute. This should wipe everything and set it to factory default. Once you go back to your browser it should ask you some basic setup questions including the initial password. It will also ask to update to the latest firmware, and I update it. Then I do NOT load any settings, I manually put them in by hand on each part of the router I want to change. Since I started doing that, I have had no issues.
- paillassouDec 13, 2020ApprenticeThanks... But... It's EXACLTLY
WHAT I've DONE ...
... and (with my bad English - I'm French) it's exactly what I've explain in my previous post...
- paillassouDec 12, 2020ApprenticeHello, I explain what I've done:
1) My R7800 has 1.0.2.68 firmware = OK
2) I reset the router to erase all personal parameters
3) At the startup, under the initial minimal configuration (router web interface) update 1.0.2.68 to 1.0.2.78.... Wait for restart...
4) At the startup 1.0.2.78, under the initial minimal configuration, I choose password.... AP MODE... Wifi WPA key... Etc... Reboot normally...
After, the router R7800 works for 5 minutes... Wifi drops, reboot randomly... WTF .... Arghhhhhh....
