paillassou
Dec 06, 2020Apprentice
Netgear R7800 Firmware 1.0.2.78
Netgear R7800 Firmware 1.0.2.78 EXACLTLY SAME PROBLEMS WITH v1.0.2.74 / v1.0.2.76 / v1.0.2.78 Router reboots randomly Wifi drops in AP MODE / unable to use AP MODE R7800 v1.0.2.78 firmware al...
JayboH
Dec 11, 2020Apprentice
After what happened to me earlier, I always now do a clean install every time and manually put in my settings instead of loading from a save. So far so good.
paillassou
Dec 12, 2020Apprentice
Hello, I explain what I've done:
1) My R7800 has 1.0.2.68 firmware = OK
2) I reset the router to erase all personal parameters
3) At the startup, under the initial minimal configuration (router web interface) update 1.0.2.68 to 1.0.2.78.... Wait for restart...
4) At the startup 1.0.2.78, under the initial minimal configuration, I choose password.... AP MODE... Wifi WPA key... Etc... Reboot normally...
After, the router R7800 works for 5 minutes... Wifi drops, reboot randomly... WTF .... Arghhhhhh....
