paillassou
Dec 06, 2020Apprentice
Netgear R7800 Firmware 1.0.2.78
Netgear R7800 Firmware 1.0.2.78 EXACLTLY SAME PROBLEMS WITH v1.0.2.74 / v1.0.2.76 / v1.0.2.78 Router reboots randomly Wifi drops in AP MODE / unable to use AP MODE R7800 v1.0.2.78 firmware al...
Dan32
Dec 30, 2020Apprentice
It might help pinpoint some commonality between who's got problems and who doesn't. Myself, I'm still on .68, I probably haven't rebooted or touched the router at all since that update came out.
Beyond router or AP mode setup, what other types of options are being used, whether you are having problems or no problems ...
- UNPNP on?
- Remote Management on?
- attaching USB devices like HDD's, USB sticks etc? (2.0, or 3.0?)
- using DFS channels for 5GHZ?
- ISP no-login (cable) or PPPOE/L2TP/PPTP (DSL and others)?
- using VPN?
- MU-MIMO ?
- Beamforming ?
- HT160?
- QOS?
- Anything else turned on/off, over and above just picking SSID name, passwords and channels?
paillassou
Jan 01, 2021Apprentice
For me
FREEBOX MINI 4K (fiber box router)
Behind, my Netgear R7800 acts as a wifi Access point. It is linked to the FREEBOX router with a simple RJ45 cable.
No other specific service are used in my case .... About 10 peripherals are connected thru WIFI on the R7800.
