paillassou
Dec 06, 2020Apprentice
Netgear R7800 Firmware 1.0.2.78
Netgear R7800 Firmware 1.0.2.78 EXACLTLY SAME PROBLEMS WITH v1.0.2.74 / v1.0.2.76 / v1.0.2.78 Router reboots randomly Wifi drops in AP MODE / unable to use AP MODE R7800 v1.0.2.78 firmware al...
supermarco
Jan 18, 2021Tutor
AP Mode, DFS Channel 64, USB HDD attached,
Experiencing random reboots as well.
I just downgraded to .68. If I see another reboot, I'll let you know.
R7800 v1.0.2.78 firmware always contains BUGS
Even with fresh and clean install...
Reset the router. Still the same problem.
Back to firmware v1.0.2.68 and everything is OK again
michaelkenward
Jan 18, 2021Guru - Experienced User
- michaelkenwardJan 18, 2021Guru - Experienced User
- nasilisJan 18, 2021Tutor
No reboots for a couple of hours on .80
- nasilisJan 19, 2021Tutor
No reboots on version .80 for more that 12 hours. Previously it rebooted multiple time in first 30 minutes after install.
I guess it is fixed at least for me.
- paillassouJan 19, 2021Apprentice
NETGEAR R7800 FIRMWARE v1.0.2.80 issuesNetgear R7800 Firmware v1.0.2.80 contains BUGS
EXACLTLY SAME PROBLEMS and random REBOOT !!!
with firmware v1.0.2.74 or v1.0.2.76 or v1.0.2.78
R7800 reboots randomly after boot up .... works 2 minutes and reboot...
WIFI drops in AP MODE / unable to use AP MODE
R7800 v1.0.2.80 firmware always contains BUGS ...Even with fresh and clean install :
Reset the router = push reset button for 10s... Still the same problem.
DO NOT UPDATE FIRMWARE v1.0.2.80 R7800Back to firmware v1.0.2.68 and everything is OK again...
NETGEAR R7800 FIRMWARE v1.0.2.80 issues - NETGEAR Communities
