paillassou
Dec 06, 2020Apprentice
Netgear R7800 Firmware 1.0.2.78
Netgear R7800 Firmware 1.0.2.78 EXACLTLY SAME PROBLEMS WITH v1.0.2.74 / v1.0.2.76 / v1.0.2.78 Router reboots randomly Wifi drops in AP MODE / unable to use AP MODE R7800 v1.0.2.78 firmware al...
michaelkenward
Jan 19, 2021Guru - Experienced User
paillassou wrote:
Could you explain how do a complete HARD RESET please ?
THANKS
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
paillassou
Jan 19, 2021Apprentice
RESET
https://www.downloads.netgear.com/files/GDC/R7800/R7800_UM_EN.pdf
page 171
Factory Settings
You can return the router to its factory settings. Use the end of a paper clip or a similar object
to press andhold the Reset button on the back of the router for at least seven seconds.
The router resets and returns to the factory configuration settings shown in the following table.
NOTHING CHANGE AFTER RESET
v.1.0.2.80 reboot or WIFI drops or lost internet (AP mode) after 5 minutes....
- paillassouJan 19, 2021Apprentice
I ask other users who are experiencing these problems to post here
NETGEAR R7800 FIRMWARE v1.0.2.80 issuesNETGEAR R7800 FIRMWARE v1.0.2.80 issues - NETGEAR Communities
- JellevJan 19, 2021Tutor
This will be my last netgear product, had the same sh*t with an R7000, now with the R7800, I'm sick of it!
- IozoneJan 19, 2021Aspirant
Easy fix. Don't use Netgear firmware. Install DD-WRT and you'll be so much happier. I certainly am.
