paillassou
Jan 19, 2021Apprentice
NETGEAR R7800 FIRMWARE v1.0.2.80 issues
Netgear R7800 Firmware v1.0.2.80 contains BUGS EXACLTLY SAME PROBLEMS and random REBOOT !!! with firmware v1.0.2.74 or v1.0.2.76 or v1.0.2.78 R7800 reboots randomly after boot up .... works...
kstotlani
Feb 03, 2021Star
Thanks for your quick response Darren. My R7800 is in AP mode. I didn't have this issue when I was on 78 version of the firmware. I know I said it reboots but I cannot confirm that. All I can see is that the AP becomes unavailable every 30-45 minutes. The white light on the router becomes orange when there is outage. The outage lasts 3-5 minutes.
paillassou
Feb 03, 2021Apprentice
this is exactly what is also happening for my router in AP MODE
with theses firmwares
1.0.2.72
1.0.2.74
1.0.2.76
1.0.2.78
1.0.2.80
back to 1.0.2.68 works normally... :/
- kstotlaniFeb 03, 2021Star
How do I go back to the old firmware?
- paillassouFeb 03, 2021Apprentice
you go here
Nighthawk X4S R7800 | AC2600 Smart WiFi Router | NETGEAR Support
you click View Previous Versionsand you download the firmware you want in order to flash the correct one...
:smileywink:
- michaelkenwardFeb 03, 2021Guru - Experienced User
Just to add to the fine advice from paillassou:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
It should be in the release notes, but Netgear has a habit of messing around with those.
- UniverseNetMar 03, 2021Tutor
Go to https://www.netgear.com/support/product/R7800.aspx#download and click the "+ View Previous Versions" link to see downloads for previous firmware verions. Apply the version before you started having issues/trouble. Good luck!
It's usually helpful to reboot the router immediately after the firmware version you applied shows up in the home sreen of your router homescreen. That makes the firmware update really apply.
