paillassou
Mar 31, 2021Apprentice
NETGEAR R7800 FIRMWARE v1.0.2.82
NETGEAR R7800 FIRMWARE v1.0.2.82 issues https://www.downloads.netgear.com/files/GDC/R7800/R7800-V1.0.2.82.zip BE CAREFUL / Read this : https://kb.netgear.com/000063040/R7800-Firmware-Version-1-0...
JayboH
Let us know how it goes
paillassou
very very sad... reboots itself after 10 minutes... wifi drops .... internet lost... :/ :/
same bugs that the v1.0.2.8x
what i've done (to be perfect... to erase all settings) :
From v1.0.2.68 fw (works fine)
RESET v1.0.2.68 fw with push reset button 30 seconds
=> router restarts with fresh v1.0.2.68 fw
launch v1.0.2.68 fw configuration wizard
SET login password
SET the router in AP mode
SET basic wifi settings
fw v1.0.2.82 update found
launch & start v1.0.2.82 fw upgrade
=> router restarts with v1.0.2.82 fw
wait 5 min to see white LED
RESET v1.0.2.82 fw with push reset button 30 seconds
=> router restarts with fresh v1.0.2.82 fw
basic wifi settings are :
(WPA2- AES SSID 2.4GHz / key = testwifi1 / azertyuiopqsdfghjklmwxcvbn123456)
(WPA2- AES SSID 5GHz / key = testwifi2 / azertyuiopqsdfghjklmwxcvbn123456)
launch v1.0.2.82 fw configuration wizard
SET login password
wait a moment... 10 min ... router reboots itsefl after ~10min ...
wifi drops... lost internet.... rooter restarts... :/ :/ :/
make me crazy .... :smileymad: :smileymad: :smileymad: :smileymad: :smileymad: :smileymad:
back to v1.0.2.68 fw works fine
