paillassou
Mar 31, 2021Apprentice
NETGEAR R7800 FIRMWARE v1.0.2.82
NETGEAR R7800 FIRMWARE v1.0.2.82 issues https://www.downloads.netgear.com/files/GDC/R7800/R7800-V1.0.2.82.zip BE CAREFUL / Read this : https://kb.netgear.com/000063040/R7800-Firmware-Version-1-0...
paillassou
very very sad... reboots itself after 10 minutes... wifi drops .... internet lost... :/ :/
same bugs that the v1.0.2.8x
what i've done (to be perfect... to erase all settings) :
From v1.0.2.68 fw (works fine)
RESET v1.0.2.68 fw with push reset button 30 seconds
=> router restarts with fresh v1.0.2.68 fw
launch v1.0.2.68 fw configuration wizard
SET login password
SET the router in AP mode
SET basic wifi settings
fw v1.0.2.82 update found
launch & start v1.0.2.82 fw upgrade
=> router restarts with v1.0.2.82 fw
wait 5 min to see white LED
RESET v1.0.2.82 fw with push reset button 30 seconds
=> router restarts with fresh v1.0.2.82 fw
basic wifi settings are :
(WPA2- AES SSID 2.4GHz / key = testwifi1 / azertyuiopqsdfghjklmwxcvbn123456)
(WPA2- AES SSID 5GHz / key = testwifi2 / azertyuiopqsdfghjklmwxcvbn123456)
launch v1.0.2.82 fw configuration wizard
SET login password
wait a moment... 10 min ... router reboots itsefl after ~10min ...
wifi drops... lost internet.... rooter restarts... :/ :/ :/
make me crazy .... :smileymad: :smileymad: :smileymad: :smileymad: :smileymad: :smileymad:
back to v1.0.2.68 fw works fine
JayboH
Does it work fine when it is set to router mode?
- paillassouMar 31, 2021Apprentice
FOR ME / FOR MY R7800
I'm only interested for AP MODE
Many RESET to erase all settings...
each RESET to test and test....
Many TEST in AP MODE...very BASIC AP MODE with simple settings doesn't work correctly...
WIFI drops / lost connection / R7800 reboot / R7800 restarts after 5~10 minutes...
it's a shame that new firmware upgrade... pffff .:/
BACK TO v1.0.2.68 works fine- MrMercuryMar 31, 2021Guide
damn...
