paillassou
Mar 31, 2021Apprentice
NETGEAR R7800 FIRMWARE v1.0.2.82
NETGEAR R7800 FIRMWARE v1.0.2.82 issues https://www.downloads.netgear.com/files/GDC/R7800/R7800-V1.0.2.82.zip BE CAREFUL / Read this : https://kb.netgear.com/000063040/R7800-Firmware-Version-1-0...
paillassou
Apr 01, 2021Apprentice
ablatt
Hello
FYI, My FRANCE ISP is " FREE "
i own a FIBER BOX ROUTER " FREEBOX MINI-4K "
Ethernet cable from my FREEBOX MINI-4K
is plugged into the WAN (yellow) PLUG of my R7800
Computer is connected with Ethernet cable into a "SWITCH" (BLACK) plug of R7800
I promise, I have test the same settings
like you on a fresh install v1.0.2.82 firmware
under v1.0.2.68 i've run firmware upgrade to v1.0.2.82
RESET done / v1.0.2.82 FW restarts
R7800 Assistant wizard
choose AP MODE and very simple WIFI SETTINGS
WPA2/AES SSID 2.4GHz = TESTWIFI1
key = azertyuiopqsdfghjklmwxcvbn123456
WPA2/AES SSID 5GHz =TESTWIFI2
192.168.0.200 fixed IP address IN AP MODE(no dhcp)
- no DFS channels
- no Smart Connect
- no Beamforming
- no MU-MIMO
- no HT160
- no Media Servers
R7800 works 5min.... WIFI DROPS... R7800 REBOOT... in loop.... each 5 min 😕😕😕😕
Back to v1.0.2.68...
ablatt
Apr 02, 2021Apprentice
The only difference for me is that when I do the firmware updates, I apply them from an Ethernet-connected PC. I then reset. I don't let the R7800 download and update itself.
